How do I add Google Adsense for Domains?
The Yola environment does not support the use of AdSense for Domains. If you would like to use this feature, you would need to move your domain to be hosted elsewhere.
Although it is not possible to use AdSense for Domains, you can put Google AdSense adverts on your pages. Here is a link to our tutorial on this topic: Adding Google Adsense.
0 out of 1 found this helpful
