How do I configure my GoDaddy domain?
If you have a domain you bought from GoDaddy.com and would like to use it to publish your site, you can use the instructions available on this link.
Please note: If you have any difficulty with the instructions in the tutorial, kindly contact your domain registrar. We are happy to help as far as we are able, and can provide instructions on how to point your domain to Yola.  However, the company that manages your domain is in the best position to assist if you run into any difficulties with the process.
If they are unable to assist you we recommend a domain transfer so that we can take care of your DNS for you: Transferring your domain to Yola.
0 out of 2 found this helpful
