Sitebuilder Classic
Submit a support request Report Abuse Sign in
How can we help you?
  1. Sitebuilder Classic
  2. Site structure and design
  3. Page layout
How do I get more space between pictures?
To get more space between two Picture widgets, an easy thing to do would be to use a Columns widget.
Articles in this section
  • Using the Panel Widget
  • Panel widget: What is this and how can I use it?
  • How do I edit the page heading?
  • How can I add a chart to my website?
  • What does column padding mean?
  • How do I make a Text widget smaller?
  • How do I move the column lines?
  • How do I get more space between pictures?
  • Content is being pushed off the page
  • How do I set space between the columns?
See more
Can't find what you're looking for?
Get in touch!
Submit a request
© Sitebuilder Classic
