Adding ratings to website
If you wish to add ratings to your site, you will need to add this through HTML coding. Here are some suggestions that you can use. Once you have the code you wish to use, you can add this through an HTML widget. Here's how:
  1. In your Sitebuilder, go to Widgets.
  3. Drag and drop an HTML widget onto your page.
  4. Paste the HTML code into the field provided.
  5. Click Save.
  6. Save and republish your site.
