Adding a poll to my site
If you would like to add a poll to your site, you will need to do a bit of HTML coding. These Google Search results provide a variety of suggestions you can use. Once you have the HTML code you want to use, you can add this to your site using an HTML widget. Here's how:
  1. Go to Widgets.
  3. Drag and drop an HTML widget onto your page.
  4. Paste the HTML embed code for your poll into the HTML Editor.
  5. Click Save.
Your poll will then be embedded in your page.
