Deleting a widget
If you need to delete a widget from your page, follow these steps:
1. Click on the "x" in the top right-hand corner of the widget box that you want to delete.
2. A dialog box will open up to confirm whether you "Are you sure you want to delete this widget?".
3. Click OK.
4. Save your work and publish your site to make the change live.
0 out of 1 found this helpful
