Changing line spacing from double to single
If the default line spacing of the Text widget is double-line spacing, you can hit the Shift-Enter keys together (Firefox and Internet Explorer) or Ctrl-Enter (Safari) when you want to go to the next single line.
If you wish to have more control over the line spacing, consider using the Style Designer.
  1. Go to Style > Designer.
  2. In the "Font" section, click Paragraph Text.
  3. Click Line Height.
  4. A slider bar will appear. Move the slider bar to increase or decrease your line spacing. You can also input a number (e.g. 2).
  5. Click Save to apply the changes to your site.
