You will need to create a .swf file on another application or flash generator that you can find on the internet. If you Google for 'create flash file' or something similar, you'll come up with hundreds of listings.
Once you've created the flash file you would like to use, you can embed the flash using the steps outlined on this link: Embedding a Flash File.
