How do I delete a folder?
Follow these steps to delete a folder from your File Manager:
  1. Click Files.
  2. Locate the folder you wish to delete.
  3. Right-click on the folder.
  4. Select Delete.
Please note: If you delete a folder which contains an image that is being used on your site, it will appear as a broken image icon on your page in the site builder. It will still appear on your live site but will be removed once you republish your site.
To view a tutorial, click here: Using the File Manager.
