How to edit fonts in the PayPal widget?
In your PayPal widget, it is not possible to edit the Product Title. However, you can change the font format of your product description. If you would like to do this, please follow these steps:
  1. Click Edit on your PayPal widget.
  2. Under Product Description, you'll see a Text Editing Toolbar where a number of font formatting options are available.
  3. If you would like to also edit your Product Title, then we suggest using Text widgets to add your product picture and description.
  4. This will allow you to format your text as you wish. Then, you can add PayPal buttons to your site.
If you wish to have a more robust and comprehensive eCommerce option, we suggest using the Online Store.
