Some styles do not allow you to change the background color or image. If you would like to customize your background, you will need to select a style which does offer customized backgrounds.
If you would like to know which styles offer the option to edit the background color or image look for styles that say Features: Background as you mouse over the thumbnails in the Style Library.
You may also like
