When want to create another gallery of photos, drag over another Flickr widget.
In your Flickr account, make sure you have given your new set of Flickr photos different tags than you were using for your first gallery or you will not get the desired result. In the Search field, enter the new tags of the photos you want to pull from Flickr.
You should now be able to bring up your next set of photos.
