Create your calendar in Excel and save it to your desktop and then add it to your site as follows:
- Go to Widgets.
- Select Popular from the drop-down menu.
- Drag and drop a File widget onto your page.
- Browse your desktop for your spreadsheet file and upload it.
- Click OK and a download link to your website will automatically be created.
- To test that the link is working, save and preview your page.
You may also be able to use Google Docs so that it's displayed on the page:
- Create or upload your spreadsheet to Google Docs.
- Publish the spreadsheet in Google Docs, you should get a toolbar opening on the right-hand side, click on More publishing options.
- A dialogue box will open, change the File Format to HTML to embed in a webpage, choose the rest of the options you want and generate URL.
- Copy the code provided.
- In your Sitebuilder, go to Widgets.
- Drag and drop an HTML widget onto the page and paste the code into the HTML Editor and press Save.
