What does column padding mean?
The Column Padding allows you to add spacing (padding) between the columns so that content from the columns do not appear to "run together" on the page.
You can adjust the padding within the columns by clicking on Column Padding. The Column Padding has a default of setting of 15px. You can control the padding for the left-hand column and for the right-hand column by either entering individual values or by using the slider bar.
We suggest using the REM values so that your content can align properly on a mobile device.
