Inserting a copyright symbol
Here is a link that will give you more information about adding a copyright symbol: Copyright Symbol.
You can enter your own copyright symbol while typing in a text box by using the correct keyboard shortcuts:
  • If you are using a PC, use ALT+ 0169 or Fn 0169
  • If you are using a Mac, use Option key+G.
