Adding quizzes
You can create a quiz through an online quiz creator. These Google Search results should give you a wide range of options to choose from.
1. Go to Widgets.
2. Select Popular from the drop-down menu.
3. Drag and drop an HTML Widget.
4. The HTML Editor will open up, allowing you to write or paste in your code.
5. When you are done, click Save and you will see the way that the HTML displays on your page.
