Setting your default payment method
You can only change your default method if you have more than one payment method set up. To change your default payment method, follow these steps:
1. Log into your Yola account.
2. Hover over your email address.
3. Select Payment Methods from the drop-down menu.
User-added image
4. Select the method you'd like to use as default and click Set as default.
5. Your default payment method will be updated.
Even if you have set one payment method as your default, you can always elect to use a different method at checkout. Overriding a payment method during checkout does not change the default - it is only applicable for that purchase and will revert to the default on subsequent checkouts.
