Adding A records
Here's how to add an A Record on your Yola-bought domain:
1. Login to your Yola account and make sure you are on the "My Yola" page.
2. Click Domains on the top menu bar and then click Advanced settings for the domain you would like to edit.
User-added image
3. To access the A Record, click Change your DNS settings.
User-added image
4. To add an A Record, click Add DNS Record.
User-added image
5. Make sure that A is selected (you'll need to add two A Records if you would like your domain to work with 'www' and without):
  • In the first A Record, leave the name blank and paste the IP address into the "Value" field.
  • In the second A Record, add 'www' under the name and paste the IP address into the "Value" field.
User-added image
The original A Records will still remain but be overwritten.
6. Click Update to make the changes.
Please note that it can take up to 48 hours for this change to fully propagate across the Internet (though usually a lot less).
Changing your domain settings can result in your site no longer working.
