This tutorial is our how-to guide for using Yola Mail. It does not cover every aspect of Yola Mail; instead, it focuses on some of the most popular features.
What browsers can I use to view my mail?
Email size and storage limits
Composing a new message
Adding attachments to a message
Inserting a hyperlink
Searching for messages
Downloading email from a POP3 account
Forwarding Email
Working with Webmail folders
Managing address book contacts
Importing and exporting contacts
Viewing email headers
Creating an email signature
Enabling an auto-reply message
Changing your email password
Changing the Webmail language
Setting the time zone
File storage and sharing files
Restoring deleted emails
1. What browsers can I use to view my mail?
- Microsoft Internet Explorer 9 and higher
- Mozilla Firefox 2.0 and higher
- Chrome 1.0 and higher
- Safari 3.2 and higher
- Konqueror 3.5 and higher
Note: You may be able to view the Yola Mail interface on other, unsupported browsers; however, some features may produce unexpected results.
2. Email size and storage limits
All e-mail accounts provide 5 GB of server side storage for archiving messages. You can send messages up to 25 MB in size.
The maximum size for email messages, including any attachments, is 35 MB; however, when attachments are sent over the Internet, they must be encoded, and this encoding increases the size of the message. The size increase can sometimes be more than 25 percent.
We recommend that you not try to send attachments that are larger than 25 MB. If you want to share large files, we recommend that you use the Files feature that is part of Yola Mail.
In addition, some mail servers will not accept large email messages, so if you attach a large file to your message, it may not reach its intended recipient.
3. Composing a new message
1. Click Mail, and then click Compose.
2. In the To field, enter the email addresses to which you want to send the message (separate multiple addresses with a comma). Alternatively, in the Contacts pane on the left side, select one or more addresses from your saved contacts list, and then click the To button at the bottom of the pane.
3. You can send a copy of the message to other addresses by entering the addresses in the Add Cc field as described above.
In the example below, the message is addressed to "info@rallyon.ca". The recipient "spencer@rallyon.ca" will receive a copy of the message and (along with any other recipient listed in the Cc field), will be able to see that the message was sent to "info@rallyon.ca".
You can also send a blind carbon copy of the message to other addresses by entering the addresses in the Add Bcc field as described above.
In the example below, the message is addressed to "info@rallyon.ca". The recipient "spencer@rallyon.ca" will receive a copy of the message and will be able to see that it was sent to "info@rallyon.ca". However, none of the recipients (in the To, Cc or Bcc fields) can see that a Bcc (blind carbon copy) was sent to "mdoucette@potpourri.com" and "peziza@hotmail.com".
4. In the Subject field, enter a subject for your email message.
5.In the large text area below, type the body of your message.
6. When you are finished writing your message, click Send to send your message.
4. Adding attachments to a message
1. While composing an email message in Webmail, click Attach a file. You can find this option in the toolbar and in the message area, and you can click either one.
2. From the pop-up window, select the file you want to attach to your message, and then click Open.
3. Click Upload.
4. The file is now attached to the message.
5. Inserting a hyperlink
You can insert hyperlinks in your messages so that, when the recipient clicks on the link, the associated web page
opens.
To insert a hyperlink in an email:
1. In the body of your message, enter the text that you want to make into a hyperlink. This can be the actual location or URL (such as http://www.example.com) or any text (such as click here).
2. Highlight the text by holding down the left mouse button as you drag the cursor over the text.
3. Click the Insert/Edit link icon.
4. The Insert/Edit Link window appears. In the Link URL field, enter the link destination, for example, http://www.example.com
5. Optionally, from the Target drop-down list, choose whether you want the link to open in the same window or in a new window. Additionally, if you wish, in the Titlefield, enter a description that will be displayed when the recipient moves their cursor over the link. Click Insert.
6. Searching for messages
This tutorial will show you how to search for a specific message in Webmail.In the Mail folders section, select the folder that you want to search.
1. In the Mail folders section, select the folder that you want to search.
2. From the Search drop-down list in the top-right corner of the window, select the type of search criteria you want to use.
3. Type your search criteria in the search field and then press Enter.
Any messages in the selected folder that match your search criteria are displayed.
7. Downloading email from a POP3 account
Instructions on how to download messages from another email account into Webmail using POP3:
1. Click Settings.
2. Click Preferences, then Other Accounts.
3. In the Other Accounts pane, click Add.
4. Complete the fields on the Add POP3 Account page as follows:
- Email - Enter the full email address of the other account.
- Username - Enter the username you use to log into your other email account.
- Password - Enter the password you use to log in to the other email account.
- Provider - From the drop-down list, choose the account's service provider.
- Server Address - The server address can be obtained from the provider of the email account you are trying to download.
- Server Port - Use port 110 if you do not put a check in the SSL box. Use port 993 if you do put a check in the SSL box.
- Use SSL - Putting a check in this box will make Webmail access your other email account through an encrypted connection.
- Leave Messages On Server - Put a check in this box if you want to leave a copy of the messages you download in the original email account.
- Default Folder - Select the folder to which you want to download the messages from your other email account.
- Test connection on save - Click to put a checkmark in this box if you want to test the connection to this account when you save the configuration.
- Import old messages - Click to put a checkmark in this box if you want to import all existing messages from the account. If you don't select this option, only new, unread messages will be imported.
5. Click Submit.
8. Forwarding Email
1. Click Settings.
2. In the Settings pane, click Mail Forwarding.
3. In the Forwarding Recipients text box, enter the addresses to which you want to forward your messages. Be sure to separate multiple addresses with a comma.
4. Click to put a check in the Enabled box.
5. Optionally, to leave a copy of forwarded messages in your Webmail account, click to put a check in the Keep local copy box.
9. Working with Webmail folders
1. Click the folder that contains messages you want to move.
2. Select the messages that you want to move.
- To select multiple contiguous items, select the first item, hold down the Shift key, and then click the last item.
- To select multiple non-contiguous items, hold down the Ctrl key and click on each of the items that you want to select.
3. Right-click and choose More, then Move to, and then choose the folder to which you want to move the files.
10. Managing Address Book contacts
Adding contacts
1. Click Address Book.
2. At the bottom of the Contacts list, click the Create new contact card icon.
3. On the Add new contact pane, enter the relevant contact information, then click Save.
Addressing email messages to contacts
There are several ways to use the Address Book to address email messages.
1. Click Mail and then click Compose to start a new message. In any of the recipient fields (To, Cc, Bcc,
Reply-To, and Followup-To), start typing the name of a contact that is in your address book. A list of the contacts whose name includes those letters appears in a list format. Click the name you want to add to that field.
2. Click Mail and then click Compose to start a new message. Click the Contacts list in the left pane to display all of the contacts that are saved in your Address Book, and then choose one or more contacts.
To select multiple contiguous contacts, select the first one, hold down the Shift key, and then click the last one. To select multiple non-contiguous contacts, hold down the Ctrl key and click on each one that you want to select. Click an icon at the bottom to choose whether to put the selected contact addresses in the To field, the Cc field, or the Bcc field.
3. Click Address Book, and then from the Contacts list, select one or more of the contacts to whom you want to send a message. Right-click, and choose Compose.
11. Importing and exporting contacts
Exporting contacts
Contacts can be exported in vCard format; the filename ends with.vcf.
To export contacts:
2. From the Groups pane, choose the group that contains the contacts that you want to export. Select Contacts if you want to export all of the contacts in the Address Book.
3. Optionally, click to select the individual contacts that you want to export. To select multiple contiguous items, select the first item, hold down the Shift key, and then click the last item. To select multiple non-contiguous items, hold down the Ctrl key and click on each of the items that you want to select.
4. From the Export drop-down list, choose Export all or Export selected.
5. Choose where to save the exported file if prompted; otherwise, check the Downloads folder on your computer for a file called contacts.vcf.
Importing contacts
To import contacts
2. Optionally, select the group into which you want to import the contacts. If you don't select a group, the contacts will be imported into the Contacts group only.
3. Click the Import icon.
4. Click Browse and navigate to the contacts file that you want to import. Select the file, and then click Open.
5. Select which address book the contacts should be imported to. The checkbox lets you delete all contacts from the selected address book before importing. Be careful with this, the deletion cannot be undone!
6. Click Import.
12. Viewing email headers
2. A window appears that contains the Internet headers as well as the content of the email message. If the email was sent as HTML you will also see the HTML source of the message.
13. Creating an email signature
2. In the Settings pane, click Identities, and then click the account for which you to create a signature.
3. Enter your email signature in the Signature text box.
4. If you primarily send formatted (HTML) messages, you can enable the HTML signature option which allows you to add formatting of your signature; when HTML signature is selected, the Signature text box displays a formatting toolbar.
5. Click Save.
6. In the Settings pane, click Preferences and then click Composing Messages.
7. In the Signature Options section, from the Automatically add signature drop-down list, choose the option to specify the way you want to display your signature:
- never - Do not display the signature.
- always - Display the signature on all messages, including new messages, replies, and forwards.
- new message only - Display the signature on new messages, but no on replies or forwards.
- replies and forwards only - Display the signature on replies and forwards but not on new messages.
8. Click Save.
14. Enabling an auto-reply message
1. Click Settings.
2. In the Settings pane, click Autoresponder.
3. Complete the fields in the Autoresponder pane as follows:
- Click to put a checkmark in the box next to Enabled.
- In the Interval field, enter the number of days before the same recipient will receive the auto-response message again. If not specified, the interval defaults to one day.
- Click in the End Date field, and select the date when you want to stop the autoresponse message from being sent.
- In the Autoresponse Text field, type the message you want to be automatically sent in reply to all incoming email messages.
15. Changing your email password
2. Click Password.
3. Enter your current email password in the Current Password field, enter your new email password in the New Password and New Password (again) fields.
4. Click Save.
16. Changing the Webmail language
1. Click Settings.
2. In the Settings pane, click Preferences, and then click User Interface.
3. From the Language drop-down list, choose your language, and then click Save.
17. Setting the time zone
3. Next to Time zone, choose your time zone from the drop-down list, and then click Save.
File sharing allows you to share files outside of email. The largest file attachment you can send in your email is 25 MB. Using file sharing, you can share or store a back-up copy of files larger than 25 MB.
Important: Files uploaded to Webmail count against your mail storage quota.
To access your file storage, click Files in the Webmail header.
You can save up to 2000 files in the Files section, with up to 1000 files in any one folder. Once a file is uploaded, you can share it with others by sending them a link to the file.
To upload a file:
1. Click Files.
2. Optional: select the folder where you want to store the file. If you don`t select a folder, the file will be stored at the top level, also known as the root.
3. Click the upload icon.
4. Browse to the file that you want to upload, select it, and then click Open.
5. The selected file is uploaded to the folder that you chose in step 2.
Note: Large files may take a few minutes to upload.
Creating folders
You can create customized folders to organize your files.
To create your own folders:
1. In the Files section, click New, and then click Folder.
2. In the text box, type a name for the new folder and press the Enter key.
Your new folder is displayed in your Files list.
Sharing files
To share files and folders:
1. Mouse over the file or folder that you want to share, and click Share.
2. Click to put a check in the Share link box.
3.The box expands to display a link for the file or folder.
4. Highlight and copy this link.
You can now use the link to share the file or folder over email, instant messenger, social networkingg, and so on.
If you want to email the link to a single address without having to copy it and then paste into an email message, you can enter an email address in the Email link to person text file and click Send.
If you put a check in the Password protect box and enter a password in the corresponding field, anyone who tries to use the link will have to enter the password you specified before they can view the file or folder.
You can also put a check in the Set expiration date and choose th edate when the link will stop working. When you click anywhere in the field, a calendar appears that allows you to choose the expiry date.
19. Restoring deleted email
Deleted email messages may be recovered by our customer service team if you contact us within 14 days of deleting the messages. Our engineering team saves back-up images of mailboxes to allow us to recover deleted email.Note: We may be unable to recover your deleted messages if:
- The email was deleted within four hours of being received. Email that has been stored on our mail server for less than four hours may not have been included in a back up image.
- You download your email using a POP3 mail program. If you use a POP3 mail program and it is configured to download messages automatically and then remove copies from our server, we will be unable to save back-up images of your messages. We recommend that you switch to IMAP if you want us to be able to recover deleted email.
