How do I copy and paste a widget?
It's not possible to copy the widget and place it in another area of the page. You would need to re-create what you have.
You can copy the text from one Text widget to another, or any HTML in the HTML widget, but make sure that you first put the text into a program such as a Notepad so any extra formatting gets stripped out as copying and pasting from one part of a page to another can cause some problems.
You may also like:
Duplicating Pages
