I have trouble editing my text
There may be a few reasons why you're having some trouble.
Did you copy and paste directly from an external source? Doing this is very likely to affect or break your page. The best way to avoid this is to first copy and paste into a program like Notepad (you should find it in the accessories folder of your computer). This will strip out any unwanted formatting and you can then safely paste into the Text Widget.
Here are some other suggestions:
  •  Are you using IE8 or IE9? Please try upgrading since we only support IE10 or newer.
  •  Try using a different browser to see if that helps.
 If none of these suggestions work, please get in touch with the Customer Support Team for further assistance.
