How to make a pop up window
If you'd like to add a pop-up window to your site, you will need to use external coding and embed this into your site using an HTML widget. These Google Search results offer a variety of suggestions you can use.
Once you have the HTML code, you can add this to your HTML widget.
1. Go to Widgets > Popular.
2. Drag and drop an HTML widget onto your page.
3. Paste in your code.
4. Click Save.
0 out of 4 found this helpful
