How can I add SSL to my site?
Yola provides you with the ability to add an SSL feature to your website. SSL is a security feature that encrypts and protects sensitive data (such as passwords, credit card information, names, and addresses) that you or your visitor send online. We strongly recommend adding this feature to give your visitors a sense of security knowing their information is safe.
The SSL feature is only available on domains managed by Yola such as the Yola subdomains or custom domains purchased through Yola.
Here's how to turn on this feature:
1. Go to Settings > Publishing.
2. Under Enable SSL, slide the toggle button to the right.
3. Republish your site and you should see the https:// in front of your domain URL.
