If you are a premium subscriber (Yola Bronze, Yola Silver or Yola Gold) you can create an unlimited number of pages for each website that you build. Yola Free users can create up to three pages per site.
It is important to remember that Yola is not designed to host sites with large numbers of pages. If you add a very large number of pages you are likely to experience performance problems. We recommend no more than 500 pages
Be aware that horizontal navigation (menu) may not support a large number of pages and this will cause the navigation tabs to run into your page. It would be best to choose a style that has vertical navigation or use our second-level menu options.
Option 1: Flyover Menu
Option 2: Submenu
