Panel widget: What is this and how can I use it?
The Panel widget allows you to create unique sections on your website's pages. This is a great way to manage, and present, different types of content so they are less overwhelming. It is also helpful if you'd like to highlight something, such as a special event or a new product in your online store.
The Panel widget is highly customizable - you can edit everything from the background color to the fonts, the border, margins and more. Once you've added the Panel widget to your page, you can start adding other widgets to it. For example, you can create a multimedia section on your page by grouping a Picture widget, YouTube widget and MP3 widget in one Panel widget.
For more information on how to use this widget, please see: The Panel widget.
You may also like:
Creating the “Flat” look with the Custom Panel Widget
