How do I delete a widget?
To delete a widget (whether it be Text, Picture, HTML or any of the pre-made widgets), simply click on the "x" in the top right corner of the widget box. You will get a dialog box requesting a confirmation on whether you want to delete the widget or not. Click OK to delete the widget.
2 out of 4 found this helpful
