Enabling a cookie notification banner
You can notify your customers that you use cookies on your site by enabling a cookie notification banner.  Here’s how:
1. In the Sitebuilder, click Settings > Privacy.
User-added image
2. Toggle the button to the right to “Show Cookie Notification”.
User-added image
3. You will see a rich text editor where you can edit the message displayed in your banner.  However, the default text and links for additional information can be used as is.
User-added image
4. You can also edit your Button text.
User-added image
5. You have the option to Preview what your banner will look like.
User-added image
User-added image
When you are done, click Save Changes and publish your site.
User-added image
Customers can click the button to accept that your site uses cookies and if they do so the banner will be dismissed.  If they do not click it, it will continue to display. You should enable this feature regardless of your location as your site visitors may come from a country where legislation requires you to inform your site visitors that your website uses cookies.
