If you've added the Flickr Widget to your page, added your account email address, and your pictures are still not showing up, you can try the following steps:
- Check your privacy settings with Flickr - if the pictures you want are marked private, they will not show up on your site.
- Make sure the tags you are using in the search are accurate and match the ones in your photostream.
- Make sure that you have used the email address associated with your Flickr account (if you have more than one email).
- Be as specific as possible in your search terms.
