If you would like to add a guestbook to your site, you will need to do a bit of HTML coding. These Google Search results offer suggestions that you can use for your website. Once you have the HTML code you wish to use, you can add this to your site using an HTML widget. Here's how:
- Go to Widgets and select Popular from the drop-down menu.
- Drag and drop an HTML widget onto your page.
- The HTML Editor will open up, allowing you to paste in your code.
- Click Save.
You should now see the guestbook on your page.
