Cookiebot Integration
Alternatively to the built-in cookie notification banner, you can use a 3rd-party solution, Cookiebot.
Cookiebot detects and controls all cookies and trackers on a website and automatically manages end-users’ consent. This tool helps to fully comply with global privacy regulations.
Note: Make sure you’ve published your website before connecting the service so that CookieBot could scan your site properly.
Adding
  1. In Sitebuilder, click Settings > Privacy.
  2. Select the Cookiebot Concent Management Platform by Usercentric option.
  3. Click the Sign up to create an account on Cookiebot link. It’s essential that you create an account using this link in Sitebuilder.
  4. After you create and confirm the account, you need to add your domain name to CookieBot. Copy your published site’s link to the Domain name field. Then click Save in the top left corner.
  5. Customize your CookieBot banner’s look in the Banner and Privacy Trigger tab. You can skip this step and return to it after you finish the integration. Feel free to refer to the Cookiebot Help Center for additional information.
  6. Copy and paste the Domain Group ID from the Your scripts tab in the CookieBot account to the respective field in the Sitebuilder and click Save Changes.
  7. Publish your site to make the changes live.
Scanning
Cookiebot will start scanning your website. As soon as the scan is complete, you will receive an email with a detailed report. Depending on your website size, this process can take up to 24 hours. You can also check the scan status under the Reports tab.
Once you have received the report, you can go to the Cookies tab and review the list of cookies found on your website.
Unclassified cookies
If you find synthasiteVisitorId and synthasiteVisitId cookies in the Unclassified category, you can manually specify their Category and Cookie purpose description as follows:
  • synthasiteVisitorId
    • Category: Statistics
    • Cookie purpose description: Registers a unique ID to keep statistics of a website visitor’s behavior.
  • synthasiteVisitId
    • Cookie purpose description: Registers a unique ID to keep statistics throughout a website visitor’s session.
Click Save to apply the changes and make them appear on your website.
